randcdavidson
Message 1 of 10 (230 Views)
Selecting Breaklines where are grips?
230 Views, 9 Replies
12-03-2012 08:05 AM
Using the select breaklines in the prospector doesn't do much of anything in my case. Zoom to Breakline works but how do you determine one particular breakline in the bunch if theye were never named?
Interesting, the Select option when righ-clicking a Breakline in Propsector selects the Surface. So no matter which breakline, or breakline group, you select, all you ever get is the surface itself (at least in 2012).
However, Robert, to help you determine which one you need the EntityTracker command in SincpacC3D (which you have) may be of some help. If a polyline or featureline is used in a surface as a breakline, it will show you the surface name and breakline name:
troma
Message 2 of 10 (229 Views)
Re: Selecting Breaklines where are grips?
12-03-2012 08:06 AM in reply to: randcdavidson
Try inserting into the drawing and see what it does.
Credit where credit is due! Give kudos or accept as solution whenever you can.
randcdavidson
Message 3 of 10 (225 Views)
12-03-2012 08:22 AM in reply to: troma
Thanks never knew that existed. Although it didn't make any difference (did not work) what is that command even for? The breaklines are already in the drawing would that be for a surface that was imported form something else like a data shortcut?
troma
Message 4 of 10 (221 Views)
12-03-2012 08:33 AM in reply to: randcdavidson
I thought it would recreate them in the drawing, redraw the object on top of the existing breakline which would help you to see which one it is from the prospector to the model space.
Another thing to try is to use the 'zoom to' command and then zoom realtime in the drawing space (not with scroll wheel).  This allows you to zoom to the centre of the view, not where the mouse is, so you end up zooming in on the exact point that the view has been centred on.  This can help you to find which object it is that you've been zoomed to.
randcdavidson
Message 5 of 10 (218 Views)
12-03-2012 08:43 AM in reply to: troma
Yeah have been having to use that. It's fine when breaklines are several hundred feet away from each other but not when they are close. I pretty much have to use zoom to then see the number of vertices associated with the breakline in the set. I then start selecting polylines until I find the one with the correct vertices, hopefully the nearest ones have a different number of vertices.
Select points grips work Where are my grips for select breaklines. If only that worked!
troma
Message 6 of 10 (212 Views)
12-03-2012 09:00 AM in reply to: randcdavidson
So many things in C3D seem to be 'a good idea if it worked'.  Wish they'd release a version that had no new features, none at all, but just made everything work as advertised!
randcdavidson
Message 7 of 10 (209 Views)
12-03-2012 09:08 AM in reply to: troma
Yeah . I have a feeling the code for "Select" under breaklines says "coming soon to a release near you"
Jeff_M
Message 8 of 10 (200 Views)
12-03-2012 09:36 AM in reply to: randcdavidson
randcdavidson
Message 9 of 10 (195 Views)
12-03-2012 10:22 AM in reply to: Jeff_M
Ah ye ole entity tracker. Great that will work perfect. Thanks Jeff.
BrianHailey
Message 10 of 10 (135 Views)
12-07-2012 06:11 PM in reply to: randcdavidson
If you create proximity breaklines or erase the entity that was used to create the breaklines (you have to turn on an option to allow deleting the entity from the drawing and keeping it in the surface), that command will put the breaklines back in the drawing. I'm guessing (can't really test right now as this computer doesn't have C3D) that if you create breaklines from a file you can use this command to insert them into the drawing as well.
Brian Hailey
CAD-1.com
My Blog
