Distinguished Contributor
TimGIS
Message 1 of 9 (744 Views)
Select using WP or CP
744 Views, 8 Replies
04-23-2012 08:29 AM
Hi All - I cannot seem to actual select or add to Selection Set using the Select --> CP/WP option.
The objects are highlighted but not selected. Therefore I cannot change the color for all the objects example.
I follow these precise steps (in the link) and end up with highlighted items but not "selected" items. The final enter command actually de-highlights to objects.
It works if you start with a modify command first such as move, and only then perform the CP/WP but that doesn't appear to be the case in the video. It would really help me out if in the end, the objects are actually selected with anchors in which i can do other things then modify.
http://screencast.com/t/5LE7obOkK
Thanks in advance,
Jeff_M
Message 2 of 9 (736 Views)
Re: Select using WP or CP
04-23-2012 09:29 AM in reply to: TimGIS
Your PICKFIRST system variable is likely set to 0. Change it to 1.
Distinguished Mentor
thepworth
Message 3 of 9 (725 Views)
04-23-2012 10:10 AM in reply to: Jeff_M
If it's not PICKFIRST then check PICKADD and make sure it is 1 also.
C3D 2011
Intel Xeon E5630@2.53Ghz
NVIDA Quadro NVS420 Dual Monitor
12GB Ram / Win7 Professional 64bit SP1
TimGIS
Message 4 of 9 (722 Views)
04-23-2012 10:13 AM in reply to: thepworth
They were both set to 1
Pickfirst = 1
Pickadd = 1
Any other pick ideas??
mathewk
Message 5 of 9 (695 Views)
04-23-2012 05:53 PM in reply to: TimGIS
Are the layers locked?
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
thepworth
Message 6 of 9 (689 Views)
04-23-2012 09:47 PM in reply to: TimGIS
I'm a little confused when I look at your screen capture again - you're invoking two selection tools outside of a command - select & qselect.  if you use a command first (eg "chprop" to change properties), do you get the same effect?
Or, if you want to add to or change your selection set, try typing "A" for Add or "R" for Remove....
C3D 2011
thepworth
Message 7 of 9 (688 Views)
04-23-2012 09:50 PM in reply to: thepworth
duh!!!!
On the bottom of the qselect dialog box, check the box for "append to selection set...."
By the way, if you want to add/remove, then do so while the command prompt still says "select objects"
C3D 2011
TimGIS
Message 8 of 9 (674 Views)
04-24-2012 05:30 AM in reply to: thepworth
Thanks for the replies.
The layers are not locked.
The video is not mine. The author has not invoked any modify/chprop or any other command proir to Select, WP, Click for polygon verticies, Enter, Enter. (18 sec marker)
At that point he has selected elements with anchors.
After that he does a qselect for some logic selections but that is irrelevant.
I guess what I am trying to figure out is what is the fundamental difference between 1. highlight and 2. selection and how do I get highlighted objects to become selected(showing anchors).
Once objects are selected and showing anchors then I can invoke quick action such as change layer or change color from the toolbars/panels/ribbons.
Thanks Gang,
thepworth
Message 9 of 9 (669 Views)
04-24-2012 07:16 AM in reply to: TimGIS
Sounds like you're as "up" on it then as the rest of us as long as you're aware of the pickfirst setting (also refered to as "noun-verb selection").  Back in the day, aka LDD / Softdesk, some routines were notorious for turning off the pickfirst/pickadd settings and not re-enabling if the routine was cancelled before completion.
Note that in addition to add/remove you can also use (P)revious as a selection group if pickfirst is turned off - check the icons up at the top of the "change properties" palette.
Best of Luck!
C3D 2011
