Civil 3D Forum
SELECT SIMILAR GLICHE?
1 REPLY 1
M!chelle
200 Views, 1 Reply
My right click shortcut to use select similar does not recognize the options I have set in the settings unless I physically type out the entire SELECTSIMILAR command.  Is this a gliche?  Or why do the settings not carry to the shortcut menu?
1 REPLY 1
Jeff_M
in reply to: M!chelle
The right click shortcut is using the AecSelectSimilar command, which is a bit different than the SelectSimilar command. A quick look in the CUI tells me this is hard coded and can't be easily changed there.
Rail Community
