akbarg
Message 1 of 4 (221 Views)
Select Object
221 Views, 3 Replies
10-18-2012 02:18 PM
Spoiler
Is there a way to select a xref by the name?
I would like to use it in a script along with Draworder, moving the xref to the back.
But this option is not in the list:
Select Object: Window/Last/Crossing/BOX/ALL/Fence/WPolygon/CPolygon/Group/Add/Remove/Multiple/P
revious/Undo/AUto/SIngle/SUbobject/Object.
You can use a line of lisp to do it for you:
(ssget "x" '((2 . "*Parcel*")))
Replace "*Parcel*" with the name of the xref you want to select. Or use wildcards as I did...what I show will select all Inserted blocks (which includes Xrefs) whose name includes Parcel. It is not case-sensitive.
Jeff_M
Message 2 of 4 (207 Views)
Re: Select Object
10-18-2012 04:19 PM in reply to: akbarg
akbarg
Message 3 of 4 (188 Views)
Re: Select Object
10-19-2012 05:05 AM in reply to: Jeff_M
Thanks!
It did the job!
Have a nice day!
akbarg
Message 4 of 4 (187 Views)
Re: Select Object
10-19-2012 05:10 AM in reply to: Jeff_M
This choice should be included in SELECT command!
