I searched thoroughly before posting this, but -- even though I'm somewhat of an ACAD novice -- I think/hope this is something I should be able to do.
I would like to quickly/easily select, and isolate, specific surfaces, with their accompanying contours, breaklines etc., so that I can work on these surfaces without the rest of my work interfering/obscuring.
Any ideas? I would put everything on the same layer, or some such, but I prefer to be able to organize what I add to surfaces in different layers, to be turned off as needed.
Thanks!! 🙂
Solved by neilyj666. Go to Solution.
And when I speak of "the objects etc. that contribute to it," I am referring to everything under the 'Definition' part of the 'Surfaces' portion of the 'Prospector' tab. Hope this is clearer!
What I am really trying to do is manipulate and change my surface by adding user-created contours, breaklines etc. I don’t keep all of these objects on the same layer, but would like to be able to isolate them, along with the actual surface, so that I can continue to define the surface.
When I isolate the surface, and turn on triangles, it seems like I am able to add and delete lines to and from the surface, but what I want to be able to do is define my surface by adding user-created contours and breaklines.
My end goal is to create a surface (usually for a drainage/grading plan) that is properly graded, and from which I can then export points for our surveyors to use for construction staking. Maybe I’m doing this in an overly tedious way, and can achieve my goal with a simpler ACAD function? Sorry for my ignorance, and thank you so much for taking the time to help!
That’s definitely quicker than manually selecting each object every time I go to isolate! I wish I could just select everything that belongs to my surface, but I’ll try this for now. Thanks again
This can be done if you use Civil3d to organize your data. I usually create a Site for my surveyed surface breaklines and a dedicated point group for the surface definition. I can use Toolspace to select the group, the site and the surface then use IsolateObjects.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
After working through this for a while, I've found the solution that works best for me is to create a 'Layer State' that has everything that pertains to the surface turned on (with everything else turned off). This makes it quick and easy to work on surfaces without the confusion of other objects etc. in the way!
"I am referring to a Civil 3D surface. I edit, and add to, it by using the 'Prospector' tab, but want to be able to isolate the surface, along with all of the objects etc. that contribute to it, so that I can see the surface (to edit it) without it being obstructed by the rest of my drawing."
If you maintain Autodesk best practices the surface is in a file all by itself, referenced into sheets and the data isolation should be as easy as unloading all xref's in the source file.
If all of the project data is in one file this become a huge PITA. In this case you will need to set up layer filters or layer states.
John Mayo
