Im having trouble displaying my sections in my section views On the section display im showing a variety of different surfaces including existing and new, all sections have Draw - checked. New surfaces are taken from my corridors. Its odd I was expecting to see at least the existing surface which covers the whole length of the site but I can only get the first 80m of the sections on my alignment to display. Sample lines do go through all the surfaces. Any help would be appreciated.
AutoCad Civils 3D - 2009 SP2
Solved by MatthewB80097. Go to Solution.
I have found a workaround for this one -
In prospector - Alignment - Sample line Groups - Properties. Sections Tab - Sample More sources. Remove all the surfaces that you have listed and add them back. For some reason this makes them appear. I have no idea why it doesn't work from the create menu in the first place.
I have followed the previous suggestion with mixed results. I got the new final surface to show, but I have some old section from corridors that are no longer valid and I don't see them in the Sample Lines - Sections, but they are still drawing in the actual sections.
Brad
C3D 2011
Vista Business 64
