I created a corridor and surface (top and datum links) using one alignment. However, I created sample lines using a different alignment. Although the corridor is available for selection in the create view dialog box, the corridor does not actually show up in the section view. The datum line for the surface shows up, but I need the actual corridor to be visible.
When I create the sample line using the corridor alignment, everything works and is visible as expected. However, I need to show more than one corridor in the same section. So.... How can I get the corridor to show up in sample lines that reference a different alignment than the corridor itself?
Thanks for all your help.
Sandy W.
AutoCAD Civil 3D 2008 SP2 on Windows XP
Edited by: swatfor on Apr 16, 2009 2:22 PM
Sandy W.
