Civil 3D Forum
Section View Styles Showing Scales in Title text
5 REPLIES 5
ShayGavaragh
988 Views, 5 Replies
I am working on setting up exagerated (10X) section views. I would like to show the horizontal and vertical scale below each section.  I have used the code below in the Axis Title Text.  The horizontal scale displays correctly (taken from the overall drawing scale)
How would i edit the vertical code below to show the vertical scale 10 times smaller?
SCALE: HORIZONTAL  = 1:<[Drawing Scale(P0|RN|AP|GC|UN|OF)]>
              VERTERTICAL  = 1:<[Drawing Scale(P0|RN|AP|GC|UN|OF)]>
Many Thanks.
5 REPLIES 5
Jay_B
in reply to: ShayGavaragh
Would something like VERTICAL  = 1:<[Graph View Vertical Exaggeration(P0|RN|AP|GC|UN|OF)]>
do what your looking for?
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Hi Jay,
Thanks for the reply. It is not exactly what i am after. Let me try to explain a bit better.
In a drawing with the scale set to 1:2000.
The code:
Write the following to the section view........
SCALE: HORIZONTAL  = 1:2000
              VERTERTICAL  = 1:2000
Your suggested code
Writes the following to the section view........
              VERTERTICAL  = 1:10
I am looking for the code to write the following to the section view
              VERTERTICAL  = 1:200
I hope this is clear. Sometimes it can be dificult to explain just using text....
Many thanks for any help.
Jeff_M
Use the GraphViewVerticalScale property.
Jeff_M, also a frequent Swamper
wfberry
It appears to me you do not need to calculate anything if you just want the vertical and horizontal scale text to show:
Horizontal =
Vertical  =
Go to the Section View Style and under the Annotation tab add it to the TITLE CONTENT.  I have my Station Number here and the notations can be centered just below it.
Bill
Problem solved.... many thanks for all replies
Jeff_M solved it with the GraphViewVerticalScale property.
VERTICAL  = 1:<[GraphViewVerticalScale(P0|RN|AP|GC|UN|OF)]>
It was right under my nose all the time!
wfberry
Thanks for reply. I did have the scale text in the Title Annotation but i wanted the title to be 3.5mm and the scale text to be 2.5mm. Hence i put the scales into the Axis title text area.
Many Thanks,
Rail Community
