When creating section view sheets how do I control where the section view is in relation to the print area. I understand I can use the data bands to force the sections left and right but what about vertically? I end up with sections drawn right on the line and the labels are outside the print area, see below.
Mark
take a look at this attachment. we use a 0.35" offset in the x direction and a 0.1" offset in the y direction.
You should be able to shift vertically by changing the height of the bands.
The problem is caused by section view bands (absent section view bands). C3D is expecting bands to be included and has not made provision for users not applying section view bands.
Solution:
Create a section view band, set all its display properties to Visibility Off (set layer to a non-plot layer for backup), use its Band details > Layout > Band height and text box width to provide the offset needed. Include the band with a zero gap below all section views in the section view group properties.
