Civil 3D Forum
Section View Pattern/Hatch Between Corridor and OG EG
3 REPLIES 3
Grimes_MG
887 Views, 3 Replies
Is there a way to add a pattern/hatch between the bottom of the Corridor Assemblies (shapes) and the OG/EG (assuming the corridor is above the EG/OG; ie. the road is in a fill condition).
I understand how to create a pattern/hatch between two (2) profiles in a Profile View but is it possible to do it in a Section View between a profile and object (corridor)?
Win7 (x64), EVGA 790i, 8GB RAM, EVGA 8800GT, 250 GB iSSHDD, & RAID 0/1
3 REPLIES 3
Jay_B
in reply to: Grimes_MG
You can show a shape style in the section views based on a Total Volume materials list comparing cut/fill from EG & Datum surfaces.
See attached 2012 tutorial file.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Grimes_MG
in reply to: Jay_B
Thanks Jay. That's what I needed.
Say, you wouldn't know if there's a way to make it so any pipes within the hatch/pattern area would show above the pattern would you? I don't want the pattern running through the cross section of the pipe. Would I have to use masking to accomplish this?
Jay_B
Grimes_MG wrote:Say, you wouldn't know if there's a way to make it so any pipes within the hatch/pattern area would show above the pattern would you? I don't want the pattern running through the cross section of the pipe. Would I have to use masking to accomplish this?
Glad to hear that helped.
Sorry I don't have an answer for that one. don't use the hatching in sections here.
C3D 2018.1
C3D 2016 SP4
Rail Community
