First time dealing with Sections in C3D and I had drawn my sections just in Model Space. The way they are drawn is they are stacked vertically up to the 7th section and then it begins a new column, I have 7 columns. I can't seem to find where you can change the max height of each column. I would like to have 5 to 6 sections per column.
Under settings in prospector, section view, group plot styles, standard plot by page (whichever you used), array tab....change the rows or columns to desired output.
All I see in the ARRAY tab is how you want your sections aligned with each other and the spacing between them. I don't see a spot where you tell how many sections or total height for each column.
That's because there isn't in 2011. Sections are layed out relative to page size in 2011. So choose a paper size and scale that will allow 5 or 6 rows.
My apologies, in C3D 2009 you could set the rows and columns. In C3D 2010 and 2011 the rows and columns are driven by a grid system that is unique to the Section Sheet.
