Having issues with where the first section view starts when trying to place multiple section views on sheets. The problem I am having is that the offset from the bottom of the sheet frame seems to be a half unit off and grid lines will not line up with the sheet gridlines we have developed. I attached a pdf of the resulting offset. Any suggestions on what I need to look for to adjust the bottom offset? Thanks in advance.
Jeff
One option is to create a band that's just the right height, but all of the dosplay options are turned off. The view will have a band and it will be moved up, but you won't see any of the band.
I also had a problem when setting up our template for 2012.
Same here, created a band style to shift it over.
