Is there a way to set your section view max and min values based on your EG surface. I've projected a property line (feature line) into my section views, problem is is that there are areas of the Feature Line that have an elevation of 0.00 assigned to it which is adding this range to my Section Views.
I'd like to clip my section views based on the max and min values for my Design and Existing or some type of value that is relavant but I don't want to set this manually for each one for obvious reasons. Any ideas welcome... Thanks in advance.
