Hello all,
Pardon my english, it's not my native language.
Right, I'm working on a pressurenetwork for a new drinkwaterpipe. I created an alignment from network using the launch pad in the associative tab.
The alignment is crossing several other pipes and cables. What I made using the alignment is a surface profile and the profile of the drinkwaterpipe. Now I want to project the crossing cables and pipes into the profile view.
Now unfortunately it doesn't 'cut' the crossing cables and pipes at the alignment intersection, which would result in circles in my profileview. Instead it projects whole strengs of pipe.
Is there any way to create a section view from an alignment from start to end, instead of sample lines perpendicular? Or is there any other solution to my problem?
Hope to hear from you experts soon!
Solved by Joe-Bouza. Go to Solution.
Your Name
Your Name
@wfberry wrote:
Joe:
His alignment does not cross the pipes. Are you still comfortable with your answer.
Bill
I think Joe has it right.
I think the OP meant the pipes don't show in the profile view as crossing, instead they show as the entire length of pipe, which would indicate that the style wasn't set correctly.
I could be wrong though.
Your Name
Really, I am possibly wrong. I would have guessed the OP would have come back by now. Not sure either way.
Bill
@wfberry wrote:Really, I am possibly wrong. I would have guessed the OP would have come back by now. Not sure either way.
Bill
Bill, Are you still comfortable with your answer? <G>
Your Name
Why when I like print from layout i can't ?
Marker ,Point number and Elevation are so large?
