Civil 3D Forum
Section View Codes are uncoded
1 REPLY 1
erik
464 Views, 1 Reply
In Civil 3D 2014 all my subassembly points in section view are catagorized as uncoded, even though they have codes in the assembly.
My goal is to label certain codes in section view.
I added the corresponding codes to the subassemblies and I updated the code set styles with those codes and defined the correct style.
I defined the style in the assembly properties and the assembly appears correctly styled (it works here).
I defined the style in the section view but all of the points appear as uncoded in section view (not working), except for one subassembly, which does show the correct coding in section view and is therefore behaving correctly.
Any idea why the points in the section view are appearing uncoded?
Thanks in advance.
Tags (1)
1 REPLY 1
erik
in reply to: erik
CAD Masters helped trouble shoot this and figure it out.
This behavior is due to the section view being generated from a different alignment than the corridor.  If you use the same alignment for the corridor and section view the points are correctly coded.
This is appears to be a bug in Civil 3d.
Rail Community
