Ok so the first time you create cross sections from corridor models has been fixed somewhat (SP2) but there is a greater issue here.
I have a series of sections created from a corridor model but after adjusting the corridor levels the surfaces display correctly but the section bands are based on the previous surface. So I delete my views then resample and redraw the sections specifying the bandset but here’s where we get some problems.
Although the sample line group references the road1 surface, corridor and existing surface it shows all other surfaces within this dialogue. So I pick the road1 surface and existing in my bandset and draw the views.
Now I go to the views and the levels don’t match the displayed sections surfaces? It’s using a surface named Road1 – sl285 – road1 road1 surface – (7) (1190) which does not exist since rebuild instead it should be using (7)(1214)? Why does this keep changing the numbers?
How do I regenerate these bands without doing each section manually? It’s a real pain when you are constantly adjusting the models.
The only other way to do this is to completely remove all section views, section line groups, adjust the corridor frequencies to the required section spacing and re do the section view group and re-draw the section views. That does work fine but would be tiresome after every change, it seems to be a bug that after one group is added and views generated if the data changes at all it will not take on the new references what so ever due to the surface name constantly changing.
