The cross section at the culdesac is not coming right (attached). Instead of a gradual slope, i get a drop near the centerline. I am targeting to the CL alignment and profile. Have anyone come across such situation?. Why is it happening.
Solved by om_gc. Go to Solution.
Solved by Joe-Bouza. Go to Solution.
Solved by Nik-D. Go to Solution.
It looks like you may have the wrong profile showing. In the properties for your profile make sure you have the correct surface selected
Nik-D
Your Name
Your Name
You guys were right. The problem was the prop. profile was little shy of the alignment. It works fine now. Thanks for your help.
