Civil 3D Forum
Section labeling
5 REPLIES 5
Strakan
494 Views, 5 Replies
Section labeling
For my cross sections, I have a template that labels my paved surface a certain way, and may daylight link another way. The issues I am running into, is when I use the rounding option on the daylight link, I get a stack of slope labels one on top of the other. Does anyone know if you can eliminate these, or perhaps have a setting to only label that portion of the daylight link that is xxx' or longer?
Thank you! Any help would be appreciated.
Civil 3D 2014
5 REPLIES 5
Jay_B
in reply to: Strakan
Short segment labels can be suppressed by using Expressions to scale the annotation of the shorter segments so it's not visible when plotted.
Expressions:
Hide Cut Segment:
IF({Link Length}>-1,0.00001,0.12/12)
Hide Fill Segment:
IF({Link Length}<1,0.00001,0.12/12)
Once Expressions are created they will be available in the label style composer of the Link Label Style and
can be chosen/applied under the Layout Tab of Link Label Style used>Text>Text height>
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Strakan
in reply to: Jay_B
How exactly do I create the expression. I am fairly new to using expressions.
Jay_B
It's fairly straight forward, Settings Tab of Toolspace>Style category (in this case)>General>
Multipurpose Styles>Label Styles>Link> bottom of the style list "expressions".
More information can be found here in Help & the Expression Tutorials
C3D 2018.1
C3D 2016 SP4
Strakan
in reply to: Jay_B
Perfect! Thank you for your help!
Jay_B
No problem, glad to help.
C3D 2018.1
C3D 2016 SP4
Rail Community
