Civil 3D Forum
Section Grid Spacing
2 REPLIES 2
212 Views, 2 Replies
Hi, Anyone know how to change the grid spacing for sections? (not the vertical scale)
2 REPLIES 2
nzeeben
Under section view styles, on the axes annotation tab. Select the major and minor tick details interval. You will need to do this for left and right, as well as top and bottom.(Depending on which portions of the display are turned on and off.)The image shows the dialog you are after.
Thanks, I've been looking right at it. "nzeeben" wrote in message news:1966704.1103743543874.JavaMail.jive@jiveforum2.autodesk.com... > Under section view styles, on the axes annotation tab. Select the major > and minor tick details interval. You will need to do this for left and > right, as well as top and bottom.(Depending on which portions of the > display are turned on and off.)The image shows the dialog you are after.
Rail Community
