I am building a corridor using multiple regions. For this area, I use two regions from my curb lines. The section editor view you are seeing in from the centerline alignment. The corridor on the right is showing the assembly correctly. The corridor on the left the assembly is backward. The double lines in the middle are my existing (top line) and proposed (bottom line) surfaces so it is making the surfaces correctly. But the look of the assemblies is wrong. Is there any fix for this?
Civil 3d 2012
Thanks.
C3D 2022 and 2024
