Civil 3D Forum
Secret to alignment line extensions?
12 REPLIES 12
Message 1 of 13
762 Views, 12 Replies
Why would I not be able to get my alignment line extensions to show in my
drawing? The C-ROAD-LNE-EXTN layer is on. The linetype is set to continuous.
There is a radius of 30' at the PI. The alignment line shows through the
radius but not the extensions. The style is set to on in display. I can't
figure it out.
12 REPLIES 12
Message 2 of 13
Did you convert a pline with a radius to an alignment. No go.
Use polylines with tangents only. Convert to alignments, then insert
curves.
Just guessing.
Bill
"Robert" wrote in message
news:5993524@discussion.autodesk.com...
figure it out.
Message 3 of 13
Yes Pline conected throught a series of PI's then converted to an alignment.
So that's the culprit.
Quick question. Since I have not had to do this yet how do you add a curve
in an existing alignment with tangents? I know how to get "rid" of one.
"wfb" wrote in message
news:5993525@discussion.autodesk.com...
curves.
Just guessing.
Bill
figure it out.
Message 4 of 13
Its on the alignment creation tool bar under the curve icon stack.. add free curve fillet between two entities with radius or through point i think its called. Message was edited by: mwright13
Message 5 of 13
Civil3DReminders_com
You can add the extensions through a curve segment label. I put a sample style here:
http://style.civil3dreminders.com/curvelineextension
Civil Reminders
http://blog.civil3dreminders.com/
http://www.CivilReminders.com/
Message 6 of 13
If you have an alignment without the extensions you can also edit the
alignment by removing the curve, use the apparent intersection osnap to
connect the two tangents & re-add the curve. The extensions will show.
I would not recommend this for normal production but when you need them you
can get them.
John Mayo, PE
Project Engineer
Conklin Associates
Ramsey, NJ
Civil 3D 2008 SP2, LDT 2008 SP2, Raster Design 2008
P-IV at 3.5 GHz
2 GB Ram
Nvidea Quadro FX w/ 128 MB Ram
figure it out.
Message 7 of 13
I'm confused here a little. From what I understand I can remove the curve
using the Edit>Alignment>Geometry, Delete Sub-entity then the alignment will
reconnect automatically, then I can re-add the curve. So why would I need to
osnap connect the two tangents as you describe?
"John Mayo" wrote in message
news:5994003@discussion.autodesk.com...
can get them.
John Mayo, PE
Project Engineer
Conklin Associates
Ramsey, NJ
P-IV at 3.5 GHz
2 GB Ram
figure it out.
Message 8 of 13
When I delete the curve I get two disconnected tangents. You can connect
them anyway you like. Stretching one tangent to the apparent intersection of
the two is just very easy for me.
John Mayo, PE
Project Engineer
Conklin Associates
Ramsey, NJ
P-IV at 3.5 GHz
2 GB Ram
news:5994332@discussion.autodesk.com...
can get them.
John Mayo, PE
Project Engineer
Conklin Associates
Ramsey, NJ
P-IV at 3.5 GHz
2 GB Ram
figure it out.
Message 9 of 13
They blocked my png. I tried a jpg on this.
John Mayo, PE
Project Engineer
Conklin Associates
Ramsey, NJ
P-IV at 3.5 GHz
2 GB Ram
news:5994424@discussion.autodesk.com...
John Mayo, PE
Project Engineer
Conklin Associates
Ramsey, NJ
P-IV at 3.5 GHz
2 GB Ram
conn
can get them.
John Mayo, PE
Project Engineer
Conklin Associates
Ramsey, NJ
P-IV at 3.5 GHz
2 GB Ram
in my
Message 10 of 13
ACADuser
Both png and jpg accesible on my end.
ACADuser
Civil 3D 2018, Raster Design 2018
Windows 7 Enterprise
Dell Precision 5810 Workstation
Intel Xeon E5-1630 v3 @ 3.70GHz
32GB RAM, NVIDIA Quadro K2200 4 GB GDDR5
DUAL 27" Dell UltraSharp U2713HM
Message 11 of 13
Thanks. OE doesn't show me the png. I will have to check my settings. I can
see the jpg.
John Mayo, PE
Project Engineer
Conklin Associates
Ramsey, NJ
P-IV at 3.5 GHz
2 GB Ram
wrote in message news:5994549@discussion.autodesk.com...
Message 12 of 13
Have you tried going to alignment properties, intersection point tab and at the implied intersecton point display option, check either 'By change in alignment direction' or 'By individual curves and curve groups'
Message 13 of 13
mathewkol
Why are you replying to a thread that is 6 years old? Your solution is not possible with Civil 3D back then. Also, there's another option to Solve PI which would solve the issue today.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Rail Community
