Civil 3D Forum
Scaling the viewing range when using object viewer
6 REPLIES 6
561 Views, 6 Replies
I'm wondering if there is a way to increase the range you see when using object viewer on a surface. For example if you have a surface that has very little elevation change how can you make it easier to pick out where those small elevation changes are?
Tags (1)
6 REPLIES 6
rkmcswain
Apply a exaggeration factor to your triangles in the surface style before viewing the surface in the viewer.
I know of a different application whose object viewer lets you change the vertical exaggeration in real-time, inside the viewer. That is super handy since different areas of your surface may need more or less exaggeration.
R.K. McSwain     | CADpanacea | on twitter
AllenJessup
Welcome to the forums. I've never seen anything that would accomplish that. Hopefully someone else may know how.
If you have the Surface exaggerated in the drawing. You can select the Surface and use 3DOrbit. That will orbit using only the selected surface.
Allen
Allen Jessup
CAD Manager - Designer
Thanks! The exaggerating of the elevations worked the way I was hoping for. Now is there a way to smooth out the peaks. The difference in elevation is where I want it but I would like to see it smooth and more realistic.
AllenJessup
The only way I know of doing that is to Smooth the Surface. That's Smooth the Surface not the Contours. See:AeccSmoothSurface
Allen
Allen Jessup
neilyj666
By exaggerating the Z value you are removing the realism are you not? Furthermore any small peaks and troughs ore exaggerrated also so making them even more peakier/troughier.
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
rkmcswain
in reply to: neilyj666
Yes, which is desired when the total difference in elevation across the site is only a few feet, which is almost everything I work with.
Rail Community
