Civil 3D Forum
Scaling points without changing elevations?
35 REPLIES 35
Message 1 of 36
kuenzlk
4612 Views, 35 Replies
Does anyone know of a way to scale points, and or objects in a 2 dimensional manner only? I've got a bunch of survey points imported from a csv file, and they are at a grid scale. I need to scale the data by a factor of 1.000125 in this case to get ground distances between the points for the client. I do not want the elevations to change. In LDDT this was not an issue as I always had the points inserted at zero elevation, but they maintained the elevation data as part of the point. It seams that in Civil 3D my points automatically appear at true elevation, so when I scale a group of points, the elevations changes as well as the elevation of any lines connected to the points. Is there a way to work 2 dimensionally with 3D data?
35 REPLIES 35
Message 2 of 36
in reply to: kuenzlk
I am pretty sure the survey database will accomplish this with the Translate
Survey Database command.
Without that, select your points & make them a block with the insertion
point coincident with the rotation base point. Select the new block & go to
the Props dialog. Insert X & Y scales, explode the block.
Look into your Point Feature Settings you can get them to insert at zero if
you want.
John Mayo, PE
Core i7 920 6GB DDR3
Radeon 4870HD 1 GB (I do not recommend this card for C3D)
Vista64
Message 3 of 36
kuenzlk
I tried the Translate Survey Database command, and it tells me I can't do this without a Survey database being open. Haven't used the survey database before, so I'm not sure what this is all about. Haven't been able to figure out how to open a survey database. Forgive me for my ignorance on may parts of civil 3d, we've just started to use it in hopes of replacing LDDT.
I tried making the points a block, and was able to scale the block as desired, but was then when I tried to explode the block, I get the message that objects were unable to be exploded.
I will try to figure out how to insert the points at zero elevation. Hopefully that will work.
Message 4 of 36
When you create the block you are prompted with the Block Definition dialog
box. Look for and check the box titled, "Allow Exploding".
The tutorials included in Help take about 10-15 mins each. They can walk you
through the Survey Database concepts & processes. I found them very helpful.
John Mayo, PE
Vista64
Message 5 of 36
ryanquigley2390
Isolate the points you want to scale. Select all. Type "scale" on the command line using basepoint 0,0 then enter your scale factor.
If you also want to scale the z values of the points then you would type 0,0,0 as the basepoint. It would then apply the entered scale factor to the Z value.
If you are also doing a Northing-Easting shift, remember that Northing is the Y and Easting is the X.
C3D 2012 SP1
Win 7 64 Enterprise
Intel Xeon 3.07 Ghz 8GB Ram
NVIDIA Quadro 4000
Message 6 of 36
I had my doubts that this would work, so I tried it...it didn't work.
Did you actually try this with Civil 3D points?
Matt Kolberg
GCS - A Division of Cansel
wrote in message news:6280500@discussion.autodesk.com...
Z value.
Message 7 of 36
ryanquigley2390
No, you are right Matt. It's not working. I tried it before (C3D 2009) and I could have sworn it worked...only modified the Northing and Easting, but after you said that I tried it again and it's not working. I must have been mistaken.
I wonder if there is a command variable for this?
C3D 2012 SP1
Win 7 64 Enterprise
NVIDIA Quadro 4000
Message 8 of 36
ryanquigley2390
When I use the 0,0 in 2004 it scales the Northing and Easting only. The same goes for 0,0,0.
In 2009 it scales all 3 when selecting either origin. (0,0 and 0,0,0)
C3D 2012 SP1
Win 7 64 Enterprise
NVIDIA Quadro 4000
Message 9 of 36
ryanquigley2390
Sorry, I didn't understand what the original poster was saying about being inserted at 0 elevation. I see now what they are saying now about the Civil 3D points being inserted at the true elevation.
C3D 2012 SP1
Win 7 64 Enterprise
NVIDIA Quadro 4000
Message 10 of 36
rl_jackson
Are you trying to get a ground / grid distance for a line (i.e. survey or traverse)?
Rick Jackson
Survey CAD Technician VI
Message 11 of 36
kuenzlk
We usually complete all our surveys at Grid. Sometimes we need to convert things to ground for a client. Sometimes we get data at ground from external sources, and we need to adjust it to fit our grid drawing. Simply depends on what we are doing, sometimes we go back and forth.
In LDDT we could scale back and forth with no problems, and the way it handled points, we were only scaling the location and not the elevation. Ideally, what I'm looking for is a way to scale 2 dimensionally with Civ3D like I was able to do in LDDT.
Message 12 of 36
Ok, I have found a way to do this.
http://www.civil3d.com/2009/10/scale-your-points-keep-the-elevations/
Matt Kolberg
wrote in message news:6279899@discussion.autodesk.com...
data?
Message 13 of 36
kuenzlk
Thank-you.
It's a pain in the rear to have to go through that process, but at least it works. I guess it's something to put in the wish list for future versions.
Message 14 of 36
Very nice. Knew there's a reason we pay you top dollar for all those
posts. 😛
JW
Message 15 of 36
Top dollar eh?
Matt Kolberg
; "P.E." wrote in message
news:6281421@discussion.autodesk.com...
posts. 😛
JW
Message 16 of 36
I'm going to sell my version of the solution for the same top dollar money: http://blog.civil3dreminders.com/2009/10/scale-points-retain-elevation.html
Civil Reminders
http://www.CivilReminders.com/
Message 17 of 36
Very nice indeed.
John
"Matt Kolberg" wrote in message
news:6281516@discussion.autodesk.com...
> Top dollar eh?
> Matt Kolberg
> posts. 😛
> JW
Message 18 of 36
You get a, ''Very nice indeed" as well.
John
"Civil3DReminders.com" wrote in message
news:6281624@discussion.autodesk.com...
> money:
Message 19 of 36
Yet another option (dialog below) ...
Terry
Never start any job without the right tools!
AutoCAD Add-on Tools at http://www.dotsoft.com
Message 20 of 36
ryanquigley2390
The original poster wrote "It seams that in Civil 3D my points automatically appear at true elevation".
You can insert the points not at their true elevation the same way you could in LDDT 2004. It won't help with your scaling issue because it still scales the elevation value using the Autocad Scale command.
In the Point display settings on one of the tabs there is a choice for how you want the point entities inserted. True elevation or fixed elevation which you can then set it to insert at Zero or whatever you want. You'll need to set this for each point display style.
When you set this to zero (or some fixed value for all point styles) you then get a horizontal distance when snapping to them using the Autocad "distance" command on the command line.
On a similar subject, I'm confused over why the scale command is able to scale the elevation of the points.
In Land Desktop 2004 you had to update the point database to reflect the coordinate values for the points after you scaled them. The point entities were moved in the drawing and you had to update the coordinate database to reflect the new position of the points in the drawing. This doesn't affect the elevations in 2004 so I assumed Autocad wasn't able to access the Land Desktop information. At least this is how it works for me. We insert our points at zero rather than "true" elevation.
Now moving to 2009 using the Autocad scale command not only do you move the point entities in the drawing but it scales the elevations.
I understand that in 2009 the point information is in the drawing, but I assumed that when you would use the Autocad scale command it would move the point entities in an x,y,z(z=entity location not true elevation) manner rather than a Northing, Easting, Elevation manner? I don't understand how the autocad scale command is able to access the elevation data and why it changes that rather than the z value of the entity itself. Does 2010 do this as well?
C3D 2012 SP1
Win 7 64 Enterprise
NVIDIA Quadro 4000
Rail Community
