I am now using Civil 3D 2013. In previous versions, SCALELISTEDIT, then Reset would give me Civil Scales. Now when I use the same command and reset, then choose Imperial Scales, it resets scales to only Architectural. I tried to make a change using_AECDWGSCALESETUP. The dwg units are already in Feet and the Type is set to decimal. How do I get back to engineering scales?
Solved by Lisa_Pohlmeyer. Go to Solution.
The default scale list can be found/set in the Options dialog. It can also be done in the registry if you're comfortable with that. I've attached an example of our Civil 3D 2013 registry file for you to review. The usual disclaimers about doing registry edits applies.
Thanks so much for the registry fix. Worked like a charm. I appreciate it.
