Civil 3D Forum
SCALELISTEDIT
3 REPLIES 3
AEC_Cadd
766 Views, 3 Replies
SCALELISTEDIT
I am now using Civil 3D 2013. In previous versions, SCALELISTEDIT, then Reset would give me Civil Scales. Now when I use the same command and reset, then choose Imperial Scales, it resets scales to only Architectural. I tried to make a change using_AECDWGSCALESETUP. The dwg units are already in Feet and the Type is set to decimal. How do I get back to engineering scales?
3 REPLIES 3
Lisa_Pohlmeyer
in reply to: AEC_Cadd
The default scale list can be found/set in the Options dialog.  It can also be done in the registry if you're comfortable with that.  I've attached an example of our Civil 3D 2013 registry file for you to review.  The usual disclaimers about doing registry edits applies.
Lisa Pohlmeyer
Civil 3D User
Website | Facebook | Twitter
AEC_Cadd
in reply to: Lisa_Pohlmeyer
Thanks so much for the registry fix. Worked like a charm. I appreciate it.
Lisa_Pohlmeyer
You're welcome. Since the 2012 install, I've made running this file a regular part of our deployment workflow. Obviously each version requires a different registry file, but it was easy enough to edit.
Lisa Pohlmeyer
Civil 3D User
Rail Community
