Show only
Search instead for
I am not LSP creator and I am trying to find a LSP that can scalelist or remove the undesirable xref scales
and leave only the specific scales I want to keep (Some Metrics)
If you happen to have one or seen it. please let me know
I will appreciate it
Autodesk have both of these utilities already created that can be run on a
bunch of files all at once.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13723349&linkID=9240698
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13723477&linkID=9240618
Matt Kolberg
Global CADD Systems - A division of Cansel
You can also add this to your acaddoc.lsp file. Every file you open will
have the scale list rebuilt. If you work with annotative objects this may
not always be ideal.
As far as the regapps cleanup goes, the following code can also be added to your acaddoc.lsp, I personally have this code as well as the code John Mayo listed in my acaddoc.lsp file and they haven't caused any noticable undesirable effects yet.
