I am working on placing boring logs in a profile. The logs come in at a 1:1 scale but the profile must be exaggerated vertically. Is there anyway to stretch/scale an object in one direction.
I currently just have plines, hatches, and text but can repaste it as a block if that will make it easier.
Solved by antoniovinci. Go to Solution.
Make a block, then insert it with scale X=Y (1:1) and scale Z exaggerated.
Thanks!! I had been making the mistake of pasting as a block instead of inserting as a block. Rookie mistake...
If the block is in the dwg, you can also select it and edit the x or y scale in the properties or quick properties dialog.
John Mayo
Hello
I've noticed one limitation in the block scaling method and curious about if there is a solution for it.
When scaling an mpolygon a burst or explode will be denied: "Cannot explode that block."
Any ideas?
