Civil 3D Forum
Saving makes the model regenerate
13 REPLIES 13
Message 1 of 14
jbear0000
780 Views, 13 Replies
Every time I save my drawing or it does an Autosave I get the message "Regenerating model" and have to wait 30 seconds for everything to regenerate. There is no reason it needs to do this, is there some way I can turn it off?
13 REPLIES 13
Message 2 of 14
in reply to: jbear0000
I have the same exact problem C3D 2008 SP2
It just started doing this in a drawing that never did this before.
"Audit" did not help.
Did you find a solution to this annoying problem?.
Message 3 of 14
jbear0000
Nope, I even contacted Autodesk on this and they couldn't give me an answer. They had me doing audits, purges, recreating the drawing etc. All things I had already tried. It seems to me that it has something to do with corridors, but I am not 100% sure that is where the problem is. If you figure anything out please let me know and I will do likewise.
Message 4 of 14
granite07
It has been a few years but I just got annoyed with the regenerating every time it saves and searched for "Civil 3D regenerates on save" and found this thread
Forest Peterson, granite@stanford.edu; build-sheet
Message 5 of 14
Try Setting SAVEFIDELITY to 0.
Message 6 of 14
peterfunkautodesk
A few questions:
1. Version of Civil 3D?
2. Have you installed all the service packs
3. Have you used fields to label your assemblies?
Peter Funk
Autodesk, Inc.
Peter Funk
Autodesk, Inc.
Message 7 of 14
granite07
yes, I have already set SAVEFIDELITY to 0
Message 8 of 14
Peter,
What is "fields to label your assemblies"
I am not sure if I have done this or not?
Message 9 of 14
in reply to: granite07
Have you tried setting LAYOUTREGENCTL to 1 or 2? It might be set to 0.
Message 10 of 14
granite07
I don't use tabs since this model will stay virtual is will not be printed; I know this a unique situation. With one tab like my model - would the Layoutregenctl still matter?
Message 11 of 14
joantopo
I generally use AutoRegen command to disable it temporary.
I had the sane issue and I think this is the best solution.
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
Message 12 of 14
granite07
I am starting to think Autodesk is like those old Nintendo games that were made purposely impossible to play unless you bought the cheat book. I give up - where is the Autodesk cheat book with all these special settings. I still want to know how big each xref dwg should be, 1mb, 3mb, 10mb?
Message 13 of 14
granite07
@peterfunkautodesk what are "fields to label your assemblies"
Message 14 of 14
granite07
~peterfunkautodesk what are "fields to label your assemblies"
Rail Community
