Civil 3D Forum
Saving Drawing
4 REPLIES 4
apweng
175 Views, 4 Replies
Saving Drawing
I'm teaching a C3D class and have been experiencing a problem with saving. Message indicates that a command is in progress when in fact none are. Other commands work. ESC does not cancel any apparent commands on progress. Can someone please advise.
I've experienced this problem as well.
Andrew
4 REPLIES 4
apweng
in reply to: apweng
FYI - We got around this by closing the window, which prompted for a save. Simply issuing the save command did not work.
nzeeben
in reply to: apweng
I have seen this issue as well, something gets hung up in the back ground. I caused it when I was copying desc keys, not sure what you were up to at the time.
apweng
in reply to: apweng
It actually did happen when we were working with description keys...
nzeeben
in reply to: apweng
The cause seems to be if you try and copy a description key in a drawing file that is not currently active.
Rail Community
