Civil 3D Forum
Save window not showing up
42 REPLIES 42
Message 1 of 43
TTamburri
164268 Views, 42 Replies
So when ever I save something I get the file path and information coming up in the command bar but I am no longer getting the extra window showing up on the screen. I was wondering if anyone has come across this before and if you now how to fix it?
Tags (1)
42 REPLIES 42
Message 2 of 43
SethHall
in reply to: TTamburri
Hi tbyrne-
Try FILEDIA and setting it to <1>. This should allow your save dialog to display again.
Hope this helps!
Seth Hall
Product Owner
Model Builder
Message 3 of 43
TTamburri
in reply to: SethHall
Thanks so much.
Message 4 of 43
Ferocity
Yea, just had the same thing here on 2011, and also some day ago on 2010. Why does it happen anyway I didn't touch a thing 😛
Message 5 of 43
rdlongbow
If you are using lisp routines, you might have one that sets filedia off and doesn't restore it if the routine fails for some reason.
Message 6 of 43
younusalirao
very very thanx
Message 7 of 43
Ramirez6j
It Worked. Great!!!
Message 8 of 43
W269118832
in reply to: Ramirez6j
Thank you!!!
Message 9 of 43
fguzma4
Thanks, it works. I am using autocad Electrical 2015. Thanks so much!
Message 10 of 43
Dominic.gm
My FILEDIA setting is already set to <1> and is still not showing the save window after pressing <OK> in plot window. What other possible solutions might there be? I am using AutoCAD Plant 3D 2017.
Tags (1)
Message 11 of 43
thanks folks!
Message 12 of 43
thank you so much i fixed it
Message 13 of 43
sakrali90
Thank you
Message 14 of 43
jawadzeinab
Thank you so much ! i had the same problem and it worked.
Message 15 of 43
cashton
genius !!! well done
Message 16 of 43
marcbruyere72
in reply to: cashton
Mine just did the same thing... Fix worked great!  Thanks!
Message 17 of 43
rosy_np
Yes it worked for me
Message 18 of 43
rashmireddy1993
thanks a lotWoman Very Happy
Message 19 of 43
blackstlian
thanks a lotttttttttttttttttttttttt
Message 20 of 43
Thanks a lot
Rail Community
