I would like to install SP-1 on C3D 2012. The download page tells me to save all customized files before installing the service pack. What items are customized? and where should I save them? Are the workspaces saved in the drawing? I have mostly customized Font files (I can find and save them), but I don't know where the Profile styles and Profile View styles, Contour and Surface Styles are saved so that I can get them to copy somewhere else.
I know this is very basic but I am a recent convert from LDT to C3D. The file selection is daunting, and doesn't make a lot of sense to the un-initiated. Can any one help?
Solved by Alfred.NESWADBA. Go to Solution.
We can't know what you have customized 😉
No, they are saved in the main-CUIX file.
These are saved in the drawing. If you created an own template you should backup this (or these) template(s).
Globally: For Win7 I'm used to backup my C:\Users\myLoginName directory (at least the Civil3D-specific directories), not forgetting that there are hidden/system folder included, so you should turn on the display of hidden files/directories in your Windows-Explorer options.
That's a tip, if you have modified files anywhere else, it's up to you to backup them also.
Good luck, - alfred -
Thanks Alfred:
I'm using XP serv. pack 3. The files are under Documents and Settings\user name\Application Data\Autodesk\C3D 2012\enu\Support. I think I can get all the ones I customized-maybe just the whole file. I didn't know the file extension was cuix. A search of .cui didn't work. There are also files of the same in a directory under program Files\autodesk\Autocad Civil 3D\Support and under UserDataCache\Support. Do I need to copy these files elsewhere also?
Richard
Look at the times/dates the files have, if the dates are older than your customization (or oder than/equel to installation date) you don't have the save.
The UserDataCache folder is not customized (normally), it's the template used when a new user logs in.
Be also careful, there are more directories under the "Documents and Settings":
C:\Documents and Settings\__username__\local settings\application data\Autodesk\....
==>but please don't mind me if that aren't the correct words used because in my German XP that are German names used for these directories.
- alfred -
Thanks Alfred. I'll check the dates on all suspected files, I never thought of that.
