I have set up my template styles for the sanitary sewer to come in on the sanitary sewer layers. I have chased this all the way back to the styles in the parts list. It looks like all sanitary pipe and structures are set to the sanitary style I have set up. Is there an automatic override I am missing or maybe some kind or box i am not checking in order for the sanitary system not to come in on the asssigned layers?????
Solved by BrianHailey. Go to Solution.
Check your network properties for the layer the actual parts are going onto (the style control the display, not the layer the part goes on).
You'll also see layers on the Profile and Section tabs as well.
When you create the network, there is the option to assign the layers:
To change the default, go into the drawing settings and set the layers on the Layers tab.
Thanks brian!!! I just assumed all my preset layers in my styles would override any others! Guess that is what I get for assuming!
