Civil 3D Forum
Sample Point file
18 REPLIES 18
Message 1 of 19
Mansourhatef
28092 Views, 18 Replies
Sample Point file
Where can I download some sample ASCII Point Files? AutoCAD 2011 does not have any sample Point File.
18 REPLIES 18
Message 2 of 19
Jeff_M
in reply to: Mansourhatef
There are a few in my 2011 install:
C:\Program Files\Autodesk\AutoCAD Civil 3D 2011\Help\Civil Tutorials
Jeff_M, also a frequent Swamper
Message 3 of 19
Here is tutorial file for you.
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Autodesk, Inc.
Please click on "Accept as Solution" if post helped you resolve the issue.
Message 4 of 19
Thanks for adding a point file.  It will help me build up  my portfolio for civil 3D.
I don't suppose you have any more point files you can share?
Tags (2)
Message 5 of 19
Here are a couple more from tutorial dataset.
Almas Suljevic
Autodesk, Inc.
Message 6 of 19
Please tell me, how can I add these points files to CIVIL 3D?
Thnx
Message 7 of 19
You've got to copy and paste the points into your Notepad (desktop) and save.
"Home" tab > "Create Ground Data" panel > "Points" > "Point Creation Tools" > "Import Points" (right most option with the arrow) > "Add Files" (+) symbol > choose the points that you have saved in your desktop!
Message 8 of 19
where is the location of point file name = existing ground point
Message 9 of 19
Thanks for contacting but I don't have now.
Message 10 of 19
a.el.rahim
in reply to: AlmasSuljevic
hey there when i imported the txt file i nothing was showing on Model screen . was it Style ?
Message 11 of 19
hallo guys i got the following data points from google earth .am trying to plot contours to use for cut and fill and the points once imported to civil 3D just appear like huge numbers not points like i see with others.someone hlp.the data is in enz form
Message 12 of 19
Pointdump
in reply to: juice.tamu254
Juice,
Your data is Lats and Longs, so you'll need to assign a Coordinate Reference System(maybe TX83-CF) before you can use those points. Make yourself a Big Ol'(Texas Talk) Point File Format set up to use Lats and Longs. Then you can Import your points and create a surface.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Message 13 of 19
You got the data points from Google Earth so they are Lat/Long in degrees, not easting/northing in feet. To use them you'll need to create a new point file format because PENZ won't be accurate due to the units of degrees and feet are not interchangeable when geolocating points in El Paso or any other US city. Negative Y-value? Uh-uh.
You will need a format like point-lat-long-elevation. Both lat and long must be in decimal degrees, not DMS, not degrees+decimal min.
Btw, if you want elevation data, Google Earth is lousy. I'd look at other online sources (there are many) because GE will make 'boxy' contours with angles approaching 90 degrees and not 'spline-like' contours normally seen on contour maps.
Chicagolooper
Message 14 of 19
oh my this is so helpful.but can you just go ahead and give me the steps of creating the new data point to match what i have.alos if you could be kind to plot the points on yourside and share the screenshot within the right point form it will really help.finally i am so new to this also if you have a better source for the data as you say kindly share the link where i can download for the same exact position.thanks and waiting to here from you.
Message 15 of 19
juice.tamu254
in reply to: Pointdump
this is super amazing .i need the contours to make a surface later but not on the ground on google earth.can you please explain how you did the new points file.i browsed and dint see that format that you have up there(PlatdeglongdegZ) how can i get it? am a complete newbie please.
Message 16 of 19
Thanks so much this is exactly what is needed. But I was wondering if it would be possibly to get a long had of the description tangs as I am not vary familiar with them. If so that would be great!
Message 17 of 19
Joe-Bouza
 make you own 😮
Really, Why? for exercise of course
Make a matrix of acad points at any spacing and elevation.
Now you get to flex DATAEXTRACTION to csv file open EXCEL>> add numbers, descriptions etc...(UDP)
play with description keys and import
and so on
11 year old post! I hate when I do that
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People)
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win10 OS
Message 18 of 19
you have exactly 1316 points. There are 19 points that don't have z-values. If it were me, I would simply delete the points that don't have z-values and keep the rest. The remaining 98.6% of points are enough to create a surface with only negligible difference.
Perform your edits in Excel. Examples of edits include, but are not limited to: adding, deleting or rearranging columns, adding or deleting rows. In the end, you'll have four columns A thru D. The format will be either PENZ or PNEZ, your choice.
A=Point
B & C=Easting & Northing (or Northing & Eastin)
D=Elevation
(You may also choose any other acceptable format allowed by AutoCAD.)
Chicagolooper
Message 19 of 19
Thanks for File
Rail Community
