It appears that the Superelevation Enumeration available in the Input/Output Parameters only returns a string. Is there a way to get the the corresponding Slope without having to check to what the value is?
I'm trying to avoid having to do a list of 8 if then statements to get the correct superelevation values.
IF((SuperSource=RightInsideLane)AND(SE.HasRightLI),SE.RightLI,1)
I'm thinking SE(SuperSource).HasValue and SE(SuperSource).Value would be a lot cleaner then using a bunch of if/then statements and would probably run a bit quicker.
Christopher
