Active Contributor
wedzisi
Message 1 of 5 (449 Views)
SAC-Subassembly (auxilary point dos not targgeting ) maby civil 3d BUG
449 Views, 4 Replies
01-10-2014 05:23 AM
HELLO EVRY ONE
I have problem with targetting in civil 3d , i allredy post one ebout that but i slove it with split coridore buy regions and geav diferent tarrgets, but now i see that if 2 points in subassembly have same target function (auxilary point and sholder  point have same target in SAC) then ayxilary point dosnot getting offset or elevation , in sac evrything works well , but in civil no , maby i am doing wrong in sac plzz can enyone check my assembly
now ebout assembly i create subbasembly for curb returne filet with sholder , sholder have merging function but it works only if auxilary point and sholder point have same parameters , but in civil 3d it dosnot working :smileyfrustrated:  plzz check attached file , sory for my bad english if somthing isnot understandebol plzz tell me  i will try explane better
Big THX
I'm having trouble understanding the purpose of creating the AuxPoints/Links and then recreating Point/Links using the same exact criteria.
For example if you need to create AP2 so that you can see where it is as part of deciding whether P13 even needs created, that would be a valid reason for creaing AP2.  But then if P13 is to be at the same location as AP2 (and if you use the same criteria for creating it, then it WILL be), I would sugguest creating P13 relative to AP2 (Delta X = 0 and Delta Y = 0).
This way if the criteria for this point ever needs to change, you only have to change it in the one location.  Plus doing it as you have it makes it a little harder to follow.
EDIT:  If you changed the criteria of one of your AuxPoints but then didn't change the associated Point, then that MIGHT account for what you're seeing.
doni49
Message 2 of 5 (432 Views)
Re: SAC-Subassembly (auxilary point dos not targgeting ) maby civil 3d BUG
01-10-2014 08:28 AM in reply to: wedzisi
Don Ireland
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Forum links:
AutoCAD 2013/2014/2015
AutoCAD 2010/2011/2012
AutoLISP, VB and other AutoCAD customization
Civil 3D General
Civil 3d Customization
Other Helpful links:
My File is too large to post or I can't post it due to privacy issues!
Active Contributor
wedzisi
Message 3 of 5 (419 Views)
01-10-2014 01:27 PM in reply to: doni49
aux links and points have same function with links and pints , they has same target same value ,in SAC works everything good , i think civil have problem with multiply target , try cut sholder in civil and you will se if you check subbasembly you will unterstand function of it , crate line from centerline til end of sholder and target on it merging sholder offset , you will get diferent result :smileyfrustrated:, i am not new in sac but also i can not say i am professional , but i thinck i have multiply taretting problem also lane side cannot accept 2 offest target same time , meby my civil is going crazy :smileytongue:
Active Contributor
wedzisi
Message 4 of 5 (411 Views)
01-10-2014 10:48 PM in reply to: doni49
i solvd thes problem thx i change points like you sad but also there was problem with calculation intersection point with AP 6 and Other points :smileyhappy: i will finish and will attach it so if somone need it can enjoy :smileyhappy:
Active Contributor
wedzisi
Message 5 of 5 (405 Views)
01-10-2014 11:48 PM in reply to: wedzisi
I attached file and enjoy whoo wants :smileyhappy: it works fine
