I am defining a Curve Link that is Parabolic in the Subassembly Composer. It seems that only crest curves are possible (positive mid-ordinate distance). Is there a way to generate sag curves (negative mid-ordinate distance)?
Kati Mercier, P.E. | LinkedIn | AutoCAD Civil 3D Certified Professional
Pronouns: She/Her
Co-author of "Mastering AutoCAD Civil 3D 2013"
AU2019 Speaker::: CES321590: Analyze and Revise Existing Subassembly Composer PKT Files for AutoCAD Civil 3D
AU2017 Speaker::: CI125544: Analyze and Devise in Subassembly Composer
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
Solved by peterfunkautodesk. Go to Solution.
Draw it the other direction by flipping the start and end points.
Peter Funk
Magical. That is exactly what it needed.
Pronouns: She/Her
