Civil 3D Forum
SAC Offset Target Is Valid Problem
3 REPLIES 3
432 Views, 3 Replies
Hello Everyone
I am using OffsetTaget.isValid in my subassembly.But i realize that when i put this formula it checks the whole drawing for that target and if the target  polyline exist even a piece of polyline in the drawing then C3D considers it for all sample lines.Is ıt possible to be able to check each single sample line if it is going to intersect that target polyline or not?
Umit
3 REPLIES 3
nilesh33
Exactly it works as you mentioned.
For this issye  I am using this method,
1. keep that offset target at zero.
2. Then add one aux point (AP5)with slope and Delta X, add same offset target
3. now replace your Is.valid formula with IF(AP5.X>0,.....)
I tried to explain my methodology, hope it will work for you too.
Nilesh
in reply to: nilesh33
Thank you very much Nilesh.That works perfect 🙂
I usually use parameter in cases like this. Integer "search width instead of a fixed value. it makes it more obvious for the user
Rail Community
