Hi all.
I am creating a corridor with custom assemblies on two alignments. the alignments are not parallel and graded independently.
Between the two assemblies I would like to fill from one assembly to the other with a dynamic link. I can't do this as a target to featureline etc as it is within the same corridor. We have created the link with a target but this was done by creating a non-dynamic featureline from the corridor and using that as the target. This is obviously not great as far as keeping the corridor dnamic is concerned.
So I would like to customise a subassembly to allow it to target a marked point on an adjacent assembly.
Can anyone assit with how the SAC tools (Get marked poinit or set marked point etc.) can be used to do this. The help file is less than useful. I am still on 2012 and dont have access to the 2014 SAC yet but will do shortly.
Thanks.
@alec.tadman wrote:Hi all.
Thanks.
I haven't used marked points so I can't directly answer the question. But you could put your two alignments in two separate corridors. Then after the one is complete, extract the featureline (and maintain DynLink). Then the other corridor can target this link.
Just because you CAN put both alignments in one corridor doesn't meant you HAVE to do so.
EDIT: I have to wonder if you could even do this with MPs -- how would the assembly know what part of the assembly in the adjacent alignment to target? There would have to be some way to correlate the stations.
EIDT2: If the reason for wanting them in one corridor is to have one surface, go ahead and create two corridors each with its own surface (both using a No Display style) and then create a third surface that pastes both of these together.
Don Ireland
Engineering Design Technician
Ok it looks like marked points probably wont do what I am looking for.
As this is within a corridor but on different assemblies, marking the point wont work.
For the moment we are just using a featureline draped on the relevant surface so it can stay live by re-draping on the surface but will need to be replaced if horizontal geometry changes.
@alec.tadman wrote:
The reason for modelling it together is to have a dynamic and combined model we can do QTO on and use for visualisation.
EDIT: I don't know what happened to my post. EVERYTHING I typed was replace with the letter 'Y'.
Anyway, I'll try again:
Having each alignment in a separate corridor each with its own surface and then pasting them both into a third surface should allow for this. I'd have to dig in to it further to be sure and I don't have time right now.
Don Ireland
