Distinguished Mentor
Civil3DReminders
Message 11 of 13 (340 Views)
Re: SAC- Marked Points
10-21-2011 06:17 PM in reply to: klugb
As long as the point number is not used in the same branch it can be used again. If the branch already has the point number then it can't be assigned again. It sounds like your point is in the same branch already, so it can't be used again.
So to use the same point number you'd have to have a decision point (or switch) which would create branches to use numbers over again.
Christopher
http://blog.civil3dreminders.com/
Valued Mentor
david.zavislan
Message 12 of 13 (322 Views)
10-24-2011 08:06 AM in reply to: klugb
My subassembly has a cut/fill condition.  Since it can't be in cut and fill at the same time, you can use the same point number once on each side of the condition.
I think for your block wall, you need to arrange it so that the last block drawn always has the same point codes, instead of adding new blocks after it as the wall gets taller.
David Zavislan, P.E. | Wood Rodgers, Inc.
Civil3DReminders.com
Message 13 of 13 (144 Views)
01-01-2014 01:33 PM in reply to: KMercier_C3D
It appears that in order to get the Marked Point to work the code needs to be all CAPS, any lower case letter makes it fail. So BLAH will work bLaH will not work.
Civil Reminders
http://www.CivilReminders.com/
