All,
I was looking through the "Enumeration_Example" file and want to create a similar one but wasn't sure how they setup an input parameter.
How did they set the Barrier type to "BarrierType"?
Also does the list for default Value come from the switch? It's A,B,C or D in the example, but I tried to switch it to 1,2 or 3 after the switch without luck.
Solved by KMercier_C3D. Go to Solution.
The BarrierType was defined by going to the View menu and selecting Define Enumeration. There you can create the Enumeration Group (ex. BarrierType) and the Enumeration Items (ex. A, B, C, D)
Kati Mercier, P.E. | LinkedIn | AutoCAD Civil 3D Certified Professional
Pronouns: She/Her
Co-author of "Mastering AutoCAD Civil 3D 2013"
AU2019 Speaker::: CES321590: Analyze and Revise Existing Subassembly Composer PKT Files for AutoCAD Civil 3D
AU2017 Speaker::: CI125544: Analyze and Devise in Subassembly Composer
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
Great,
NOW I know what I'm looking for I found it in the help files.
Ok, now I have a different issue.
I have been getting errors with my version of the subassembly that I built from the example. I went back and tried the original one and still get the same errors so it's either my computer or the code has always had an issue.
Have you (or anyone else watching) used the "Enumeration_Example.pkt" downloaded from Autodesk?
I get " [FooterWidth (Double): 301 : Value cannot be null." error message.
Never mind, found it. It was an issue with the original code:
