Hello Everyone, I have prepared a railway subassembly which has two tracks. For cant calculation i made use of the railway cant example.pkt which is available on autodesk sample pkt files. However, after running that sa in civil 3d, i saw that the cant works according to inputted gauge width parameter on alignment properties, since you can input only one gauge width, the cant is applied as if there is only one track with two rails and the calculated cant is applied on these two rails only. But, what i need is to apply that cant on both tracks seperately. is it possible to override that gauge width input and make the cant applied on the tracks seperately? For instance, the default gauge of alignment is 1500 mm and the calculated cant is 40 mm. So civil 3d automatically applies that cant on 750 mm left and right and my rails which are beyond 750 mm fit on the extended slope with much more elevation. What i need is to have that 40 mm cant on one of the rails on both sides (origin+40m in elevation).
