I added two output parameters in my custom SA. I no longer want them in there. But I can't find a way to delete them.
Does anyone know how?
TIA!
Don Ireland
Engineering Design Technician
Solved by doni49. Go to Solution.
I could've sworn that I tried this yesterday. But I tried again and it worked.
Highlight the parameter and pick the delete key on the keyboard.
Don Ireland
Don
Were you able to consistently delete a parameter without issue? I find that often when I delete a parameter SAC locks up. Also when I add a perimeter it seems to be random as to where it places the new box in the list. Very aggravating if you are trying to keep the parameters in a certain order.
