Civil 3D Forum
SAC converge after a switch
1 REPLY 1
kevinjackman
319 Views, 1 Reply
Using the subassembly composer.
I have created a switch for 4 different curb style geomtries.  Switch works great.
After the switch, I want to bring the branches back together.
I want the next point to be common.  Trouble is, I have 4 possible origins.
How do I validate the origin for this next point?
C3D 2012
Tags (1)
1 REPLY 1
KMercier_C3D
in reply to: kevinjackman
Posting a screenshot of your current flowchart would be helpful. If you are using the same numbering system in each branch you would use the same Point Number for the common point and then you can reference that point number for the remainder of the geometry.
Kati Mercier, P.E. | LinkedIn | AutoCAD Civil 3D Certified Professional
Pronouns: She/Her
Co-author of "Mastering AutoCAD Civil 3D 2013"
AU2019 Speaker::: CES321590: Analyze and Revise Existing Subassembly Composer PKT Files for AutoCAD Civil 3D
AU2017 Speaker::: CI125544: Analyze and Devise in Subassembly Composer
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
Rail Community
