klugb
Message 1 of 4 (276 Views)
SAC- Absolute Value
276 Views, 3 Replies
10-07-2011 07:54 AM
Is there a way to get the absolute value using the subassembly composer? I was checking the elevation difference between two points and just want the delta regardless if it's positive or negative.
Bruce Klug
AutoCAD Expert Elite
AutoCAD Civil 3D 2014 Certified Professional
Infrastructure Design Suite 2014 (SP2)
Testing Civil 3D 2015
Win 7 Pro, 64-bit
Try: math.abs(p2.elevation-p1.elevation)
KMercier_C3D
Message 2 of 4 (273 Views)
Re: SAC- Absolute Value
10-07-2011 07:56 AM in reply to: klugb
Kati Mercier, P.E.
Co-author of "Mastering AutoCAD Civil 3D 2013"
AutoCAD Civil 3D 2013 Certified Professional and AutoCAD 2013 Certified Professional
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
klugb
Message 3 of 4 (269 Views)
10-07-2011 08:02 AM in reply to: KMercier_C3D
Thanks!
Tried the "abs" but forgot the "math."
Bruce Klug
Win 7 Pro, 64-bit
Employee
peterfunkautodesk
Message 4 of 4 (261 Views)
10-07-2011 08:35 AM in reply to: klugb
There is a link in the help file to the Microsoft site that lists all the functions in the .NET Math library. You can use all of these inside of SAC. However, if you think you need trig functions you might want to revisit the point options and intersection options. I don't think I've needed to use trig yet.
Cheers,
Peter Funk
Peter Funk
