Hi all,
Has anyone here had an issue running an assembly offset along a static Corridor Surface-derived profile? I don't know if that's my problem at present, I'm just trying to eliminate posssibilities.
My scenario: I'm trying to run two lanes around either side of an island, a little like an island in the middle of a cul-de-sac but one lane continues on beyond and the island shape isn't exactly as offset of the EOB alignment. Thus, I need an offset to make the corridor sections turn and correctly define the island.
However, the lane crossfall defines the elevation of the edge of island, so I've built the corridor with just a lane to the island edge alignment and extracted the profile from the corridor surface. Having then set the profile's update factor to "static", I then re-enter the Corridor Properties dialog and try to apply to the alignment offset the appropriate alignment and the new static profile. Result: the corridor builds (as in the blue progress bar down the bottom flicks through to 100% for each region), then Civil 3D hangs without displaying the newly built corridor.
Any ideas anyone?
Thanks in anticipation,
Trevor
