Member
0 Kudos
Post 1 of 8
rt lisp routine
283 Views, 7 Replies
10-22-2012 12:43 PM
when I load a lisp routine "rt".... it wipes my osnap settings.
343 Kudos
Post 2 of 8
Re: rt lisp routine
10-22-2012 01:39 PM in reply to: toonook77777
It's the (SETVAR "OSMODE" 1) that is doing this (resets to endpoint, presumably as part of the lisp routine). I don't know what the lisp is doing (rotating a view perhaps??) as I'm not a lisp expert - there are other contributors to the forum who are and may be able to suggest something.
As an aside, I have put my preferred OSNAPS in a right click macro so i can always reset if i need to temporarily alter them.
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 500Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
Member
0 Kudos
Post 3 of 8
Re: rt lisp routine
10-22-2012 01:44 PM in reply to: neilyj
so OSMODE 1 is what is killing my osnaps? What should it be set to to prevent this?
485 Kudos
Post 4 of 8
Re: rt lisp routine
10-22-2012 01:56 PM in reply to: toonook77777
I don't have time now. But if no one has chimed in on how to use GETVAR to save the OSMode. I'll get back to you in the morning.
Allen
343 Kudos
Post 5 of 8
Re: rt lisp routine
10-22-2012 02:31 PM in reply to: toonook77777
i guess you could reset the osmode at the end of the lisp. Allen is one of the lisp gurus i mentioned so will give better advice than me. you will need to obtain the osmode value that corresponds to your preferred settings. Set them via options as usual and type OSMODE and note the value displayed (help will explain how the value is derived)
neilyj
485 Kudos
Post 6 of 8
Re: rt lisp routine
10-23-2012 04:50 AM in reply to: toonook77777
OK. Since you probably don't write much lisp. The easiest way to fix this would be to add 2 lines to the lisp code. Add the bold line where shown.
C:RT ()
(setvar "cmdecho" 0)
(setq OM (getvar "osmode"))
(setq OB (entsel "\Select object for base angle: "))
Add this line near the end of the lisp.
(setvar "osmode" OM)
The first line sets the current osmode to the variable OM. The second line resets the osmode using the OM variable.
Allen
485 Kudos
Post 7 of 8
Re: rt lisp routine
10-23-2012 04:55 AM in reply to: neilyj
Sorry to dissuade you Neil. But I'm just a dabbler. I stopped doing anything serious in lisp when autodesk and third party covered most of what I wanted to do. The only things I can do in VLisp is to paste together some things by example.
Allen
343 Kudos
Post 8 of 8
Re: rt lisp routine
10-23-2012 05:29 AM in reply to: AllenJessup
If you can anything in lisp - you are a guru...:smileywink:
neilyj
