Civil 3D Forum
Roundup Pipe lengths in Labels to nearest 6 inch intervals in Civil 3D
7 REPLIES 7
Message 1 of 8
1350 Views, 7 Replies
When labeling pipes in a pipe network; is there a way or expression to roundup the label to 6 inch interval. For example, if I have a pipe length of 2.6 feet, I want to roundup this to 3.0 feet and if I have a pipe length of 2.4 feet, I want to roundup this to 2.5 feet.
If anyone can help me with, I would really appreciate.
7 REPLIES 7
Message 2 of 8
ToddRogers-WPM
In the label style, I think if you truncate it, it will round it.
Todd Rogers
Message 3 of 8
in reply to: ToddRogers-WPM
I already tried truncate but it's not working.
Message 4 of 8
troma
Might have to use an expression.
What does truncate do, exactly?
Mark Green
Working on Civil 3D in Canada
Message 5 of 8
ToddRogers-WPM
in reply to: troma
Truncate is supposed to round the numbers.
However, here is a blog about creating an expression to round the numbers...
http://ontariocivil3d.blogspot.com/2011/02/civil-3d-label-styles-using-expressions.html
Todd Rogers
Message 6 of 8
BrianHailey
Truncate will drop the decimal, not round it.
trunc(1.1)=1.0
trunc(1.9)=1.0
trunc(-1.9)=-1.0
Ceiling returns the next highest integer.
ceil(1.1)=2.0
ceil(1.9)=2.0
ceil(-1.9)=-1.0
Floor returns the next lowest integer.
floor(1.1)=1.0
floor(1.9)=1.0
floor(-1.9)=-2.0
In your case, you want the next largest half number so your expression will look like this:
CEIL({2D Length - Center to Center}*2)/2
1.4 becomes 2.8 becomes 3.0 becomes 1.5
1.6 becomes 3.2 becomes 4.0 becomes 2.0
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Message 7 of 8
ToddRogers-WPM
Well that's not confusing. Thanks for the clarification in the truncating though.
Todd Rogers
Message 8 of 8
BrianHailey
in reply to: BrianHailey
You have to be careful. If you have two labels for the same length, you might end up with some odd results. If the length is 110.04 and you label it out to the tens place with and without the expressions, you'll see:
110.0 without the expression
110.5 with the expression
If this is important, you can do more in the epxression to account for this.
GEI Consultants
My Civil 3D Blog
Rail Community
