How can I evaluate and expresion to the nearest tenth?
Never did this but the list of available functions says to wrap your math in this, ROUND(x).
http://docs.autodesk.com/CIV3D/2012/ENU/filesCUG/GUID-448A4BEC-C1D1-404F-83B5-0C0E3B46ABB-2156.htm
John Mayo
The rounding functions are listed along with the rest of the math functions in the expression dialog box.
http://screencast.com/t/eiwAQhfa
CEIL rounds up, FLOOR rounds down
Try:
ROUND(X/0.1) *0.1
Out of curiosity, why don't you just use the label properties to round it? I'm sure there are reasons but I just gotta know.
And Freds second post would be the way to do it.
I don't mean to sound flippant, but isn't an integer a whole number? I want to deal with the decimal portion.
Yes, I'm sure you do.
This goes back to the earlier thread where the user wanted to label low points in plan and I suggested doing it with alignment labels that use the profile geometry. I can get the low point and high point labeled, I added a third element; the driveway elevation for top and bottom of curb.
I have a road rehab job where I profiled the gutter at a min 0.30% up and down and across the driveway aprons.
I created 3 label components LowPoint, HighPoint, DriveWay:
Lowpoint text height says IF({Grade In}-{Grade Out}<0 ,0.008,0)... If the Algebraic difference is neg I should see LP {profile elevation} and the other two labels go to zero
Highpoint text height says IF({Grade In}-{Grade Out}>0,0.008,0)... If the algebraic difference is pos I should see HP {profile elevation} and the other two labels go to zero
Driveway text height says IF({Grade In}-{Grade Out}=0,0.008,0)..If the algebraic difference = 0 (on grade) I should see a multiline label
TC{profile elevation + [expression that adds 0.12 to profile elevation}
BC{profile elevation, and the other two labels go to zero
I'm not getting the driveway labels. They are coming in as LP{elev} and HP{elev}.
So my thought was when I inserted the PVI on grade even though it displays 0.30% the expression may be see 0.299999999902? I'm guessing.
Do you see a flaw in my logic(opened myself up for all kinds of comments there)? I know I could use surface label styles but that would mean I'd have to have a surface. I'm only replacing the C&G so I was not thinking corridor.
I'm not exactly sure I follow but I think I do.
In one situation I had, I wanted the label to be green if the slope was greater than 2.0%. The problem I ran into was if the label was 1.99% the label would still display as 2.0% but wouldn't be green. So what I did was to change the expression. Instead of testing to see if the slope was 2% or greater, I tested to see if it was 1.95% or greate (which is the lower limit of numbers that round to 2%).
So when you say your "road needs to be 3.0% or greater" what you are really saying is you "road needs to be a number that rounds to 3.0% or greater".
Make sense?
Attached is a file with said label style in it. It's from a lab I taught at AU 2008.
I though I could hide labels similar to the method for cut and fill tics.
this might explain what I am trying to get. Sorry our system will not let me DL your dwg to examine. could you email it? jbouza<at>cameronengineering<dot><com>
