Neilw
Message 11 of 28 (435 Views)
Re: Rotating the View of a Drawing
10-11-2012 08:17 AM in reply to: dankoss
I find the Align Space tool in the Express tools works nicely for aligning viewports to model space lines or picked points. Basically it is a macro that automates the process of applying a DVIEW TWIST. Be aware that it will also scale the viewport to fit your picks, but once you get the view rotated it is easy to reset the scale.
Neil Wilson (a.k.a. neilw)
Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
WIN 7 64 PRO
HP Pavillion h8xt, i7 2600, 12 GB
RADEON 6450, 1 GB
http://www.sec-landmgt.com
Valued Contributor
rick.hberg
Message 12 of 28 (428 Views)
10-11-2012 08:34 AM in reply to: dankoss
Save the lisp file to some location of your choosing.  From there, there are many ways to load....one is:
type APPLOAD. Then you can browse to the file and press Load. This loads it in the active drawing.
In the same dialog, if you do like the routine and want it to auto-load for you in each drawing...pick the Contents button by the briefcase, then pick Add, and browse to the file again.
The commands - for the RVIEW.lsp (with UCS to View) the command is RVIEW
for RVIEW2 (UCS to World) the command is RVIEW2
Civil 3D 2014
Windows 7 x64
BrianHailey
Message 13 of 28 (404 Views)
10-11-2012 03:54 PM in reply to: dankoss
Set VPROTATEASSOC to 0, rotate the viewport.
Set VPROTATEASSOC to 1, rotate the viewport back.
Done.
http://screencast.com/t/76Z4957XG
Brian Hailey
CAD-1.com
My Blog
Neilw
Message 14 of 28 (396 Views)
10-11-2012 04:54 PM in reply to: dankoss
Unless I am missing something you shouldn't need a LISP routine for this. You already have one with the Express tools.
http://screencast.com/t/aWvsawyY
WIN 7 64 PRO
RADEON 6450, 1 GB
Valued Contributor
rick.hberg
Message 15 of 28 (386 Views)
10-11-2012 06:31 PM in reply to: dankoss
I agree that you don't need a lisp routine to rotate the view - it's purely user preference.
To just rotate the view in the viewport (or in Model space), RVIEW is much faster - type RVIEW and pick two points - done.  Want to get the view back to World - type RVIEW and pick W - done.  Want to specify an angle to rotate the view - type RVIEW and enter the angle - done.  I just don't like the multi-step procedures of the other installed options.
But sure, other commands are out there...mvsetup is pretty nice to line up plan and profile viewports....and if you wanted to rotate the physical viewport with the view - then definitely vprotateassoc is the way to go.  Totally user preference is all I'm sayin'
:smileyhappy:
Civil 3D 2014
Windows 7 x64
antoniovinci
Message 16 of 28 (373 Views)
10-12-2012 02:03 AM in reply to: rick.hberg
It's faster, but misleading, as every routine based on UCS commands.
As stated by Allen, the only right solution in the model space is _DVIEW => _TWIST
AllenJessup
Message 17 of 28 (362 Views)
10-12-2012 05:00 AM in reply to: dankoss
Actually. The whole thing would be much simpler if AutoCAD would let you set the VIEWTWIST from the command line. I'm attaching an old lisp that will set the Snapangle parallel to the rotated view.
Allen
Valued Contributor
rick.hberg
Message 18 of 28 (359 Views)
10-12-2012 05:04 AM in reply to: Neilw
Antonio, you're right (I was thinking inside the box - how we do it here)...
RView forces UCS to View
RView2 forces UCS to World
RView3 never gives UCS any thought...(attached).
Thanks for the critique...
Civil 3D 2014
Windows 7 x64
AllenJessup
Message 19 of 28 (350 Views)
10-12-2012 05:24 AM in reply to: rick.hberg
Rick,
That looks promising since it doesn't use a UCS. I had to add (vl-load-com) after the local variables to get it to run. I'd say that if your going to use a lisp to set the viewtwist that this would be the best one to use.
Allen
AllenJessup
Message 20 of 28 (348 Views)
10-12-2012 05:25 AM in reply to: BrianHailey
Nice trick!
Allen
