Imported points and I have a label style to label tree sizes automatically, but when there are many trees near each other labels start to overlap. So I will typically rotate the label style 180 degree or drag the label, but I am curious if its possible to have label always stay horizontal no matter what my rotation angle is.
What Dan said. I did exactly that for exactly the same reason yesterday. One tip. If you're aiming for a viewport with a Viewtwist set. Consider twisting your modelspace view to the same angle. It will make the dragged the labels look correct. If you don't want to do that. You can either work through the viewport or maximize the viewport.
Allen
Allen Jessup
CAD Manager - Designer
I have it set to view, so it comes in horitzontal, but when I select the point and select the node for the label and select rotate the label, label stays at an angle. See attached pics. As I rotate the label around the point how can I get the label to always stay horizontal. Forgot to mention this is being done in 2013
When you select the grip you have the option of rotating the marker or marker and label, just do the marker
Rick Jackson
Survey CAD Technician VI
if the orientation is set to view the point label should not rotate with the node. please double check your setttings for the individual point as well as the point group.
I am not rotating the point itself, just the label. How do you upload a video? I have a video of how its acting now as .swf created through jing. Or if its possible if you could insert a pic or video. Thanks for any help.
